You are not logged in.
#1 2009-08-20 01:13:19
MC
Administrator
Website
Latest Driver Updates USB
a new firmware is available for the Fireface UC. Version 88 fixes: In Quad Speed operation SMUX4 did not work. The mic gain fader position of channel 1 sometimes changed on ASIO start. In QS mode the analog input channel 1 (mic) did not work correctly.
Offline
#2 2009-09-04 10:37:12
MC
Administrator
Website
Re: Latest Driver Updates USB
We released firmware 91 which fixes problems with the pitch fader and SPDIF output channel status.
We also released a combined Mac driver for the Fireface UC (version 1.14), that should work in 10.5 32 bit, 10.6 32 bit and 10.6 64 bit.
Offline
#3 2009-09-15 05:08:09
MC
Administrator
Website
The new Mac driver 1.16 adds support for sleep mode and provides the updated TotalMix design.
Offline
#4 2009-10-02 12:50:40
MC
Administrator
Website
The new Mac driver 1.17 fixes a state problem at Double and Quad Speed after Standby.
Offline
#5 2010-01-27 18:22:41
MC
Administrator
Website
Version 0.936 for Windows fixes the broken ASIO Direct Monitoring support.
Offline
#6 2010-04-01 20:31:10
MC
Administrator
Website
Version 0.938 improves standby operation (possible even when WDM and ASIO are active) and WDM related channel configurations (Loudspeaker, surround).
Offline
#7 2010-07-08 22:21:59
MC
Administrator
Website
Firmware 111 is now identical on Mac and Windows. It adds USB 3 compatibility (not functionality!) and 24 bits for SPDIF consumer status.
Offline
#8 2010-10-15 21:19:40
MC
Administrator
Website
Fireface UC: Firmware 112 fixes a problem in stand-alone mode where the sample rate was not set correctly (note: 111 is shown as up-to-date in the FUT, disregard that).
Windows driver 0.959 adds official support for Fireface UFX with TotalMix 0.91. The Fireface UC will use TM FX as well starting with this driver.
Attention Fireface UC! The former TotalMix autorun entry is not deleted by the driver, therefore has to be deleted by the user before (or after) the driver update. Remove the entry
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\FirefaceUsbTray2 = firefaceusbmix.exe
The most easiest and safest way to do this is to double-click on the file
remove old mixer autostart.reg
which is found within the driver archive. Windows will then remove the autostart of the old mixer. (Note: if you downloaded the driver before please download again, the reg file is now included).
Offline
#9 2010-11-04 06:04:48
MC
Administrator
Website
Windows driver 0.961 and Mac driver 1.48 continue our current update mania. The latest UFX FireWire firmware  is now also found in the Mac flash tool.
Offline
#10 2010-12-03 15:28:24
MC
Administrator
Website
Windows driver 0.964 includes TotalMix FX 0.924 and a bugfix when using multiple WDM devices. Mac driver 1.49 includes TotalMix FX 0.924.
Offline
#11 2011-02-04 15:15:17
MC
Administrator
Website
Babyface Mac/Win: Firmware 1.79 activates Zero Crossing detection for the microphone gain stages (reduced clicks when changing gain with audio present), and removes a small bug in the USB core that fixes several compatibility issues, like compatibility to Mac OS < 10.5.8.
Offline
#12 2011-03-28 17:53:35
MC
Administrator
Website
Fireface UFX: The DSP firmware has been updated from 110 to 111. Compressor/Expander were in stereo mode not coupled reliably, so worked in dual mono mode instead.
Offline
#13 2011-03-31 20:45:50
MC
Administrator
Website
Fireface UFX: The DSP firmware has been updated from 111 to 112. V 112 had introduced a minor bug which has been fixed.
Offline
#14 2011-06-17 14:27:28
MC
Administrator
Website
The latest driver is now 0.983 (Windows) and 1.58 (Mac). Lots of changes and improvements for FF UC, Babyface and UFX, see driver readme. The Direct USB Recording feature of the UFX is now officially released.
Offline
#15 2011-10-12 09:56:18
MC
Administrator
Website
New drivers have been released:
Windows USB 1.01
Mac 1.61
They bring a new TotalMix FX and new features for the UFX (as announced in this forum before, with DSP firmware 141).
Offline
#16 2011-11-02 22:05:18
MC
Administrator
Website
A new Win/Mac DSP firmware for the UFX (v 144) fixes a serious bug with version 141. Please update!
Offline
#17 2012-01-19 05:44:22
MC
Administrator
Website
Lots of news! New Win USB driver 1.019. New Mac USB driver 1.65. Both include TotalMix FX 0.963, several fixes, and support for the new Fireface UCX. This comes along with an updated firmware for the UFX (DSP 147) for Mac and Win, with further improvements and fixes.
Offline
#18 2012-02-09 22:32:22
MC
Administrator
Website
The new Mac USB series driver 1.66 solves a small but annoying problem for the UFX and UCX: if the system sample rate is 44.1 kHz and the unit has been set to a different one (for example in stand-alone mode), then booting the Mac with the unit attached the sample rate was not set to 44.1 kHz. Fixed.
Offline
#19 2012-02-17 13:01:40
MC
Administrator
Website
Windows 8 includes a new USB driver called xHCI (which also adds native USB 3 support). Our current USB driver crashes during installation under Windows 8. The soon to be released driver 1.020 should be fully compatible with Windows 8. If you want to (and can) try:
http://www.rme-audio.de/download/driver_usb_win8.zip
Offline
#20 2012-05-22 21:47:10
MC
Administrator
Website
Driver 1.022 has now been released. It brings full Windows 8 XHCI compatibility and some minor fixes and improvements.
Offline
#21 2012-05-31 09:26:05
MC
Administrator
Website
Mac USB driver 1.72 is now available on our website. It includes some nice changes: Supports multi-user operation, Changed buffer handling for 10.7.4, Fixes channel order in 10.7.4 (UFX), Installer signed for 10.8. The latter means that we tested the driver successfully with the current version of 10.8, but will not officially call it 'compatible' unitl the final OS has been released by Apple.
Offline
#22 2012-07-13 15:03:36
MC
Administrator
Website
Windows (1.024) and Mac (1.73) drivers including TotalMix FX 0.983 have been uploaded to our website. The new Mac driver also fixes a problem of distortion/noise that occured only on some machines, and sometimes only after a longer time of usage.
Offline
#23 2012-08-07 15:54:46
MC
Administrator
Website
Mac driver 1.75 fixes wrong channel order for the UFX (reintroduced in 1.73), has TotalMix FX 0.984, and fixes a TM disconnect problem after sleep under 10.6.8.
Offline
#24 2012-08-27 23:56:39
MC
Administrator
Website
Windows driver 1.025 now includes TotalMix FX 0.984 which fixes D2D scaling problems.
Offline
#25 2012-09-07 17:29:43
MC
Administrator
Website
Mac USB driver 1.76 is highly recomended for use with 10.8 and up, as it fixes several issues that had been reported in this forum, plus some others:
- Workaround for playback problem after sleep
- Bugfix crash when turning the encoder of UC/BF while the computer -
- Fixed clock domain prevents the unnecessary use of sample rate conversion in multi-unit operation (Aggregated Devices)
- Red button in the Settings dialog closes the window
- Change: Device was sometimes not removed when disconnecting it under 10.8. This also caused wrong sample rates and playback device settings on reconnection.
- Further improved setting of the former sample rate on reconnection.
- Internal stream IDs optimized
- TotalMix FX 0.985: Bugfix disconnecting the UFX caused slow reaction when then other RME USB devices are connected. Open GL is now allowed to use alternative renderers.
Offline
#26 2012-11-27 13:18:11
MC
Administrator
Website
We released firmware 201 for the Babyface, adding stand-alone mode and Class Compliant mode (iPad!). The firmware update tool also includes firmware 117 for the UC, which fixes an internal loopback problem with the ADAT channels.
Offline
#27 2012-12-11 12:21:32
MC
Administrator
Website
Firmware 203 turns the flashing instrument input LED (which many people did not like) into a constantly lit one, but with reduced brightness. Only in CC and stand-alone mode, in normal operation the LED is off as before. Also a bug in the Mac firmware has been fixed that caused distortion on echo/reverb.
Offline
#28 2012-12-21 18:53:59
MC
Administrator
Website
Latest drivers released on our website: Windows 1.028 and Mac 1.078, including the latest TotalMix FX 0.989.
Offline
#29 2013-01-24 20:27:53
MC
Administrator
Website
Firmware 220/CC4 extends the UCX Class Compliant mode to 18 channels and 2 playback routing presets.
Offline
#30 2013-02-14 04:34:35
MC
Administrator
Website
Windows USB driver 1.029 includes a small improvement where the Settings dialog's Lock registry option has been fixed.
Offline
#31 2013-02-24 04:22:05
MC
Administrator
Website
Windows USB driver 1.030 fixes a small problem for few users with the computer hanging on shutdown.
Offline
Board footer
Powered by PunBB
© Copyright 2002–2005 Rickard Andersson
