Driver Updates Hammerfall DSP System
List of current and older driver updates
Windows 2000/XP Driver
Version 2.94(3) (FUT 15_106_53_152): Inf file updated for new firmware 15 and 53 (PCI and CardBus). Bugfix 96 kHz: channel 1 playback distorted when SPDIF signal present. (12/2005)
Version 2.94(2) (FUT 14_106_52_152): TotalMix: Fixed small memory leak. Automatic submix selection when activating Monitor Main/Phones. MIDI Remote: Starting TotalMix via a click on the systray symbol refreshes the LC-Display. (11/2005)
Version 2.94(1) (FUT 14_106_52_152): Bugfixes for HDSP 9632: TotalMix settings were not loaded correctly after Standby/Hibernation. Quick Access Panel graphics reset added. Level meter display problem (numerical) in some specific situations - fixed. General: TotalMix MIDI remote: Mute and solo buttons were not always displayed correctly. (09/2005)
Version 2.94 (FUT 14_106_52_152): TotalMix: Since 2.93(3) ASIO Direct Monitoring had been inactive. Internal Loopback optimized (digital I/Os). (07/2005)
Version 2.93(3) (FUT 14_106_52_152): TotalMix: Performance improved when Matrix window is open. Tooltip is turned off when window is closed via ESC. Tooltip is turned off when mouse is moved quickly across the window border. Graphical problems with 9632 and RPM fixed. General: Plug and Play behaviour of the Settings dialog optimized. Internal bugfix (registry access) which did not cause any trouble so far. (07/2005)
Version 2.93(1) (FUT 14_106_52_152): HDSP series: ASIO offset values added. Dummy GSIF-2 MIDI ports are now fully functional. MME MIDI In and GSIF-2 MIDI In can be used simultaneously. Bluescreen fixed on power-down of certain computers (W2k SP4 Dual CPU). TotalMix: Small error fixed in factory preset of RPM and HDSP 9652. Tooltip no longer sticky when 'Always On Top' is off. Systray context menu improved, new entry 'Matrix'. Matrix window titlebar shows current preset. Digiface: 'Emphasis' is valid for the analog Phones output too. Digiface, Multiface, HDSP 9652, HDSP 9632: Option 'SyncAlign' added to Settings dialog. HDSP 9652: Option 'Word Clock Out: Single Speed' added to Settings dialog. Internal loopback in TotalMix removed - not possible with this card. (06/2005)
Version 2.92: Bugfix Digiface, Multiface, RPM: disabled internal loopback got reactivated by fader movements and MIDI data. HDSP9632: DDS implementation had been incomplete (ASIO), causing several errors. (05/2005)
Version 2.91: TotalMix: Performance improved when MIDI option LC-Display is active. MIDI: Cursor up/down no longer jumps to other channelsDigiface/Multiface only: Quick Access Panel no longer active when only output row is visible. HDSP9632: New hardware (Flash Update 152) with internal loopback, DDS and improved ADAT receiver. DDS added to settings dialog. Internal loopback can be activated via TotalMix. (05/2005)
Version 2.90(1): New TotalMix with Monitor Panel, MIDI support and a lot more improvements. Digiface/Multiface: changed order of AutoSync sources, Word is now on top. Improved ADAT receiver. New option Word Clock Out Single Speed. Digiface/Multiface/RPM: support for internal loopback. With Flash Update Tool 13/51: Digiface/Multiface: Bugfix communication problem at certain sample rates. Note: the MME driver based Host-controlled automatic monitoring (Samplitude, Sequoia, SAWStudio) is no longer supported. (05/2005)
Version 2.831: Improved initialization of Digiface/Multiface/RPM when reconnecting it. Support for HDSP9652 firmware 105. (04/2005)
Version 2.83: Completely rewritten code for loading the mixer settings on boot-up. (03/2005)
Version 2.82 (a): Internal signal error in the RPM hardware caused sample errors on the left channels. TotalMix displays invalid routings, which are generated when changing from single to double speed, as blank field (RPM/Multiface). New TotalMix: 'Link Faders' activates a global stereo control of all faders (hotkey L). (07/2004)
Version 2.82: AutoSync mode now also prevents sample rate changes when ASIO is running in double or quad speed mode. When using multiple CardBus or PCI cards: ASIO can be used even when not all I/O boxes are connected to the installed CardBus/PCI cards. False RPM detection hopefully improved. Bug fix: The setting 'Pref Sync Ref' wasn't used by the hardware. Settings dialog shows up in Systray, even if the CardBus is not inserted when booting the laptop (but TotalMix does not work without a reboot. This mechanism will be changed later to the one of the Fireface). (06/2004)
Version 2.81: 'Always on Top' deactivated in TotalMix caused delayed playback/recording up to freezes of the audio software. (05/2004)
Version 2.80: Floating point calculations in TotalMix could cause a crash of TotalMix. Scrollwheel used in TotalMix causes changed Preset indication. Not initialised variable in the ASIO driver could cause ASIO to stop in multi-client operation. In seldom cases the MIDI driver could cause a freeze of the computer. Bypass mode of the RPM is now defaulting to 'Phono 0 dB' until the driver is loaded. (05/2004)
Version 2.7a: MME playback changed RPM Input 1/2 from Phono to Line. TotalMix: graphics error when using scroll wheel in third row fixed. (04/2004)
Version 2.7: General news, changes and fixes - Driver: Added complete support for the RPM. Full GSIF 2.0 audio support (record and playback). TotalMix settings of HDSP 9632 and HDSP 9652 are automatically reloaded after sleep mode. At first time installation of Multiface/Digiface/RPM a default routing configuration is loaded into the mixer. MME: In AutoSync mode, a request for a different sample rate than the input one (caused a change to Master mode) is no longer supported. ZLM did not work correctly in double speed mode. Digiface only: in double speed mode, sequential start of the record devices caused channel 3/4 to become corrupted. TotalMix: Added vertical scrolling in TotalMix mode, horizontal/vertical scrolling with floating labels in Matrix mode. Added Delete (menu Edit or Del-key). Added scroll-wheel support. Release time of the Level Meters in Double and Quad Speed mode corrected. ASIO Driver: Using more than 2 HDSP devices caused the ASIO channel list to become corrupted.
HDSP 9632 Specific: New firmware with several improvements. Word clock input has been out of phase (180). RMS calculation (TotalMix, HDSP Meter Bridge) did not work correctly on some channels, especially at higher sample rates. SPDIF receiver has not been fully compatible (Tascam DA-30 did not work). Word clock input now supports quad frequency ratio. Word clock output now supports double and quad speed frequency. Frequency indication AES Channel Status on output for quad speed corrected. Driver: Use of ASIO caused the AES (XLR) input to switch to Coaxial (SPDIF). Added word clock output option to Settings dialog. ADAT I/O returns correct error message in quad speed mode. (3/2004)
Version 2.64: New: Mute button added to Phones section of HDSP 9632. Slow reaction of the Settings dialog fixed (introduced in 2.63). Driver deactivation fixed. (12/2003)
Version 2.63: Changes: Support for power management. Improved callback routines in multicard operation. New: Disconnect mode for Digiface and Multiface. Error detection in I/O box improved. (12/2003)
Version 2.62(1): Bug fixes: TotalMix routing problem with Multiface (introduced in 2.62). HDSP 9632 SPDIF AC-3 did not work. Missing MIDI ports in multi-card operation. Small display error in TotalMix. GSIF support for HDSP 9632 fixed. (09/2003)
Version 2.61: New: ASIO for HDSP 9632 extended. Added support for HDSP 9632's AI4S-192 and AO4S-192. Improvements: TotalMix saves files more reliable on shut down of Windows. Flash Update Tool operates more reliable. (07/03)
Version 2.60: New: TotalMix rewritten. New features: Matrix view, Multiwindow view, Group operation, Copy/Paste operation and lots more. ADM steers TotalMix faders. Added support for the HDSP 9632. Added routines for buffer misses detection. Bug fixes: Last used sample rate is stored reliably. ASIO multiclient compatible to Sonic Foundry Vegas. (07/03)
Version 2.52: New: ASIO multi-client operation. Bug fixes: HDSP general: SPDIF out: non-audio was set when not required. ASIO double speed compatibility improved. HDSP 9652: TotalMix settings were not loaded automatically into the second card. (04/03)
Version 2.51: New: Support for DVD multichannel playback 4/6/8 channels (16 bit/48 kHz). Bug fixes: HDSP general: TMS setting wasn't stored correctly. HDSP 9652: TotalMix settings were not loaded automatically into the second card. (02/03)
Version 2.434: ASIO erase routines added for multiclient operation (noise in Sonic Foundry Vegas). Modified MIDI handling of invalid data (prevents crash of Gigastudio). (02/03)
Version 2.433: Bug fixes HDSP General: ASIO Direct Monitoring did not work correctly at 88.2/96 kHz. (12/02)
Version 2.432: Bug fixes HDSP General: I/O Box sometimes detected as HDSP 9652 - no loading. Setting Non-Audio Bit during AC3 playback did not work reliable. Changes HDSP General: TMS (Track Marker Support) implemented. ADAT Double Speed is signalled in the ADAT data stream. FUT_11_104: New MIDI hardware: significantly reduced system load. TotalMix: ASIO Direct Monitoring can be switched off (emagic Logic). (12/02)
Version 2.42: Changes: HDSP general: Non-audio bit is set automatically when playing back AC3 or DTS. HDSP 9652: AEB input/output now functional. 'ADAT1 Int.' and 'SPDIF Internal' added to Settings dialog. (11/02)
Version 2.41: Bug fixes: HDSP general: In MME mode record position has not been reliable (0 or -1 buffer deviation). HDSP 9652: 'Analog' within the TotalMix routing menu has been removed. Changes: Driver simplified. Default.vol and Preset.mix files now integrated into the driver. Default presets available via CTRL key. (10/02)
Version 2.4: Added support for HDSP 9652. (10/02)
Version 2.332: On some computers MIDI position was incorrect and MIDI/audio position drifted. (6/02)
Version 2.331: Improved performance of the second HDSP at low latency and high CPU load. (6/02)
Version 2.33: Latency setting not synchronized when using more than one card. Digiface: no MME operation possible with ADAT3 input only. Multiface: Check Input did not work with ADAT Input when no ADAT signal was present. TotalMix: ZLM buttons were invisible but active, when display of Inputs was off. (6/02)
Version 2.323: Start settings of TotalMix were not correct. BPM kernel driver did not work. Multi-client ASIO/MME operation did not work when using two systems. Saving settings on shutdown did not work. Saving a preset changed default.vol file. ASIO GetClockSources fixed. New driver: slightly improved record performance under MME. (5/02)
Version 2.32: Multi-client ASIO/MME operation did not work when using two systems. Saving settings on shutdown did not work. Saving a preset changed default.vol file. (3/02)
Version 2.31: New driver: No alternative ASIO dll anymore (audiomidifix) - this one is now standard. Icon of the Settings dialog is removed when program is closed. No display in Settings dialog when I/O box is disconnected. No MME/ASIO operation when I/O box is disconnected. Saving of the last used sample rate. New TotalMix: Changed 'Exit' routines, closes program window immediately and fixes crash situation. Window size wasn't maximized after changing between single and double speed. Arrows for changing 'samples for over' value were working the wrong way. Bugfixes: Under certain conditions Sysex data crashed the MIDI driver. TotalMix caused error in I/O box detection. (3/02)
Version 2.22: New driver: Fully multi-client operation of ASIO, MME and GSIF. (2/02)
Version 2.2: New driver: GSIF support added. ASIO reset switched off monitoring on channel 1 (Digiface/Multiface.) New TotalMix: graphics update Multiface channel 9 fixed. Bugfix: Speaker Protection for phones out did not work on Multiface. (2/02)
Version 2.1: New driver: Modifications for ZLM implementation. Settings dialog's systray right click menu now closes correctly. Uninstall improved and extended (\Software.) New TotalMix: Added ZLM and monitoring modes Mix/Replace. Error in preset 4 and 8 removed (Mute Master was not activated.) New Hotkeys I, O, P, S and F2. Hotkey Alt now also functional with Mute and Solo. Systray right click menu now closes correctly. Bugfixes: ASIO SetSampleRate did not return error when not executed. (12/01)
Version 2.01: I/O box detection improved. New Flash Update Tool with new hardware versions, now separated into PCI card and CardBus card (fixes problems with Apple Titanium only so far.) (11/01)
Version 2.0: New driver: Completely new I/O-box design with phase locked inputs and outputs (0.) Intelligent Clock Control. Frequency measurement and display of all inputs signals. SyncCheck of all input signals (new: SPDIF, word clock.) Check Input also for word clock. Complete support for Multiface. Simultaneous operation of Multiface and Digiface. Extended HDSP bus protocol. Verification of hardware revision (firmware of PCI-/CardBus interface.) Weblinks added in About page and hardware warning page. Flash Tool for updating (external program.) HDSP Meter Bridge (external program.)
New TotalMix: Support for up to three systems. Warning message when trying to save presets in write protected files. Complete support for Multiface. Automatic adaptation of TotalMix in Double Speed operation. Dialog Level Meter Setup Options. Always on Top. Deactivate Screensaver.
Bugfixes: Re-insertion of the CardBus card. Word clock as Pref Sync Ref wasn't activated automatically. ADAT Sync Clock did not work. TotalMix crashed when trying to write into write protected files. (11/2001)
Version 1.01: Bugfix: no sound under Logic-ASIO when MME was used first. MME device names changed (as in W98 driver.) (07/2001)
Version 1.0: Initial release. Based on Hammerfall driver v. 1.381, plus TotalMix, complete ASIO 2.0, CardBus and Digiface support. (06/2001)
Windows 98/SE/ME Driver
Version 2.431: Bugfixes HDSP general: ASIO Direct Monitoring did not work correctly at 88.2/96 kHz. (12/02)
Version 2.43: HDSP general: ASIO Direct Monitoring was broken since version 2.40 - fixed. Added support for TMS (always active). FUT_11_104: New MIDI hardware: significantly reduced system load. TotalMix: ASIO Direct Monitoring can be switched off (emagic Logic). (12/02)
Version 2.42: HDSP 9652: Added support for AEBs. (11/02)
Version 2.4: Added support for HDSP 9652. (3/02)
Version 2.13: TotalMix: ZLM buttons were invisible but active, when display of Inputs was off (6/02)
Version 2.12: Saving settings on shutdown did not work. Saving a preset changed default.vol file. (3/02)
Version 2.11: New driver: ASIO reset switched off monitoring on channel 1 (Digiface/Multiface.) New TotalMix: graphics update Multiface channel 9 fixed. Bugfix: Speaker Protection for phones out did not work on Multiface. (2/02)
Version 2.0: New driver: Completely new I/O-box design with phase locked inputs and outputs (0.) Intelligent Clock Control. Frequency measurement and display of all inputs signals. SyncCheck of all input signals (new: SPDIF, word clock.) Check Input also for word clock. Complete support for Multiface. Simultaneous operation of Multiface and Digiface. Extended HDSP bus protocol. Verification of hardware revision (firmware of PCI-/CardBus interface.) Flash Tool for updating (external program.) HDSP Meter Bridge (external program.)
Bugfixes: ADAT Sync Clock did not work. (11/2001)
Version 1.01: Bugs fixed: the file default.mix was not copied during installation. Mute and Solo wasn't activated correctly when loading a Preset. Analog output needed MME playback to be activated. No click anymore at the analog out when booting (Speaker Protection.) The new driver installs 8 Presets for the mixer. (06/2001)
Version 1.0: Initial release. Based on Hammerfall driver v. 2.61, plus TotalMix, complete ASIO 2.0, CardBus and Digiface support. (06/2001)
Mac OS X Driver
Version 1.6c (FUT 14_106_52_152): Bugfix Multiface: The HDSP 9632 bugfix in version 1.6b caused the Multiface to be limited to 10 channels. (10/2005)
Version 1.6b (FUT 14_106_52_152): Bugfix HDSP 9632: Internal loopback had been active after system boot in some cases, so that record data seemed to be missing. TotalMix: New menu entry TotalMix with hotkey T. Both menu and hotkeys now also operate with closed windows. MIDI remote improved (note off). (09/2005)
Version 1.6a (FUT 14_106_52_152): Driver constantly wrote into the system log - fixed. New icons for the Settings dialog. HDSP 9652: Level meters of TotalMix showed wrong values. (08/2005)
Version 1.6 (FUT 14_106_52_152): Newly programmed Settings dialog and TotalMix, featuring Auto Load, Dock Lock and Auto Remove. Added firmware revision check to Settings dialog. Input Offset and Output Offset values added. Digiface/Multiface: changed order of AutoSync sources, Word is now on top. Digiface/Multiface/9652: Improved ADAT receiver. New option Word Clock Out Single Speed. With Flash Update Tool 13/51: Digiface/Multiface: Bugfix communication problem at certain sample rates. Digiface/Multiface/RPM: Support for internal loopback. Improved initialisation when re-connecting the box. Digiface: 'Emphasis' is valid for the analog Phones output too. HDSP9632: New hardware (Flash Update 152) with internal loopback, improved ADAT receiver and DDS. DDS added to Settings dialog. New TotalMix with Monitor panel, MIDI support and a lot more improvements (based on current Fireface driver 2.20). (07/2005)
Version 1.5 (g1): New MIDI Plugin with reset of the MIDI port names. The extended names of driver 1.5g were not used by OS X in case the devices had already been there (former driver use). (06/2005)
Version 1.5 (g): New scheme for improved multi-card operation. The PCI slot number is now added to the device name. The order no longer changes on reboots. (05/2005)
Version 1.5 (e): Bugfix MIDI: Settings dialog caused a repeated MIDI note at the HDSP9652 and 9632 MIDI output. (11/2004)
Version 1.5 (d): Bugfix MIDI: Bigger sysex packets became corrupted. (08/2004)
Version 1.5 (c): Internal signal error in the RPM hardware caused sample errors on the left channels. TotalMix displays invalid routings, which are generated when changing from single to double speed, as blank field (RPM/Multiface). RPM default state is now Bypass and Phono 0 dB. RPM TotalMix routing AN 5+6 changed to Phones. Added Presets to TotalMix for the RPM. New TotalMix: 'Link Faders' activates a global stereo control of all faders (hotkey L). Bugfix TotalMix pans did not work correctly when window made smaller so that scrollbars show up (v 1.5b). (07/2004)
Version 1.5: New MIDI driver with rock-solid timing even on old computers at high CPU load. MIDI device name for RPM corrected. (03/2004)
Version 1.4: Added complete support for the RPM (driver, settings, TotalMix). Added card number in multidevice operation to device and each stream name. Changed settings dialog tabs: number and card type. Added support for the Flash Update Tool. Added workaround for Apple's Aluminum Powerbooks (freeze fix, recognition of hardware revision 12). Added workaround for crash on wakeup from sleep on dual G4 Macs. Loading TotalMix settings on wakeup from sleep now works for Digiface and Multiface too. The system profiler no longer claims the driver to be incompatible and not loaded. Improvement of the PCI bus performance. Depending on the model of your computer this can cause a dramatic improvement of lower latency with less clicks. TotalMix: Hotkeys I O P S X added to menu. 128 kHz, 176.4 kHz and 192 kHz added to HDSP9632. Added option 'Word Clock Out always Single Speed' to HDSP9632. Settings dialog displays word clock input frequency also for double and quad speed. (02/2004)
Version 1.3: CoreMIDI: improved MIDI timing. Added support for power management (resume/sleep). Disconnect mode: Freeze of the current hardware state with all settings and even TotalMix. Improved I/O Box error detection and re-lock. Speaker Protection on phones out of Multiface/Digiface. Added hotkeys to load presets in TotalMix. All TotalMix factory presets have 'RMS +3 dB' activated. TotalMix RMS release time is now identical for single, double and quad speed operation. In case the I/O box is missing at boot, the driver will default to a Multiface. (12/2003)
Version 1.2: TotalMix: Matrix, group-based operation, copy/paste, scrolling, multi-window operation and delete whole routings via selection/menu Edit have been added. TotalMix has been reprogrammed from scratch for better Level Meter and scroll performance. General: Added support for the HDSP 9632. Added CoreMIDI for HDSP 9632, HDSP 9652, Digiface and Multiface. Settings dialogs improved, unneccessary hard drive access removed. (10/2003)
Version 1.1: TotalMix: HDSP 9652: 'Analog' removed from routing menu. Routing in 96 kHz operation was incomplete. Driver: Higher compatibility through increased offset. (02/2003)
Version 1.0: Initial release, complete functionality based on FUT 11/104. (01/2003)
Mac OS 9.x Driver
Version 2.21: TotalMix settings were not loaded automatically. (02/2003)
Version 2.20: Modified for Flash Update Tool 11/104. Changed TotalMix control, new internal bin files, improved MIDI hardware. (01/2003)
Version 2.11: New TotalMix: automatic exit on shutdown. (6/2002)
Version 2.10: New driver: OMS MIDI support. New ASIO driver concept with separated drivers for single and double speed operation. Digibox.bin and multibox.bin merged into the driver file. Version resources added to all files. Default SPDIF input changed from optical to coaxial.
New TotalMix: Hotkeys I/P/O/S/L in TotalMix (Input, Playback, Output, Submix view, Level meter setup dialog.) Hotkey P (for numerical peak display) in TotalMix changed to E.
Bugfixes: TotalMix Multiface bugs fixed (graphics errors.) (3/2002)
Version 2.01: New TotalMix: Dialog Level Meter Setup Options with several settings added. Hotkey Alt for Mute and Solo added. (12/2001)
Version 2.0: New driver: Intelligent Clock Control. Frequency measurement and display of all input signals. SyncCheck of all input signals (new: SPDIF, word clock.) Complete support for Multiface. Simultaneous operation of Multiface and Digiface. Extended HDSP bus protocol. Verification of hardware revision (firmware of PCI-/CardBus interface.) ASIO 96 kHz support improved. Several changes for compatibility to Digital Performer. Flash Tool for updating (external program.)
New TotalMix: Support for up to three systems. Complete support for Multiface. Automatic adaptation of TotalMix in Double Speed operation. Dialog Level Meter Setup Options.
New hardware: new hardware versions through flash update, now separated into PCI card and CardBus card (fixes compatibility problems with Apple Titanium.) (11/2001)
Version 0.91: New hardware version with phase locked I/Os (improves compatibility to Tascam 4000 and Creamware converters.) Small bug in TotalMix (PAN) fixed. ADAT Sync did not work in clock mode AutoSync nor ADAT Sync. (9/01)
Version 0.9: Initial release: Based on Hammerfall driver v. 1.6, plus TotalMix, complete ASIO 2.0, CardBus and Digiface support. No MIDI/OMS. (7/01)
Copyright Matthias Carstens.
All entries in this Tech Infopaper have been thoroughly checked, however no guarantee for correctness can be given. RME cannot be held responsible for any misleading or incorrect information provided throughout this document. Lending or copying any part or the complete document or its contents is only possible with the written permission from RME.
