      • 60-Channel, 24-Bit 192 kHz USB & FireWire Audio Interface
      • 36-Channel, 24-Bit 192 kHz USB & FireWire Audio Interface
      • 56-Channel, 24-Bit 192 kHz FireWire Audio Interface
      • Bidirectional 64-Kanal 192 kHz MADI / AES3-id Format Converter
      • Optional Expansion Boards for HDSP PCI cards
      • External monitoring remote for Fireface UFX/UCX and others
      • Universal analog XLR/SUB-D Breakout Box
      • Universal XLR/SUB-D Breakout Box
    • Cables&Adapters
      • Cables and Adapters for RME products
      • Rackmounts for RME products
Rackmounts
  • Acccessories
Accessories
ALVA Rackmounts
Rackmount RM-19
Adapter for 9,5" devices
RM-19
RM-19
Rackmount adaptor to mount half 19" RME units into a 19" rack: RME Fireface 400, Multiface 2, ADI-2.
Just remove the factory-mounts and replace them with the RM19.
More information: ALVA Website
Unirack 19 II
Unirack 19 II
19"/1U Universal Rackmount Unit for non 19" units like e. g.: RME Multiface, Multiface II, Quadmic, ADI-2, Fireface 400, ADI-4 DD and many other units. We updated some of the drill-hole's positions, reduced weight, removed rear "teeth". The sheet material is much leaner than at the MK-I version. The oplong slits on the back are designed to be used as strain-relief by using cable-straps, the ones before can be used to mount e. g. AC-adaptors on the UNIRACK 19/II.
