      • 56-Channel, 24-Bit 192 kHz Firewire Audio Interface
Products: Accessories
Perfect partners.
Accessories
HDSP Expansion Boards
Optional Expansion Modules for HDSP series
The Expansion Boards transmute RME's digital cards of the DIGI96 series, Hammerfall series and the HDSP 9652 into the most flexible audio cards available. The AEB - Analog Expansion Board - offers 4 or 8 additional analog Inputs or Outputs as non-expensive extension for all ADAT-capable cards. Modules with TDIF and Word Clock connections are also available.
The following expansion modules are available:
  • AI 4S/192 - 4 analog inputs with 192 kHz analog-digital converters
  • AO 4S/192 - 4 analoge outputs with 192 kHz digital-analog converters
  • TEB - TDIF I/O
HDSP TCO
Optional Time Code Module
The optionale extension for chosen HDSP PCI- and PCI Express cards. The little module provides the mother card with a Word Clock input and offers synchronization to LTC, Video and VITC. With the help of SteadyClock the module extracts not only absolute positioning data, but also a very low-jitter Word Clock. The TCO guarantees the perfect connection and a sample accurate timecode synchronization to audio and video signals.
Features
  • 1 x Word Clock Input
  • 1 x Video Sync Input (alternative to WC In)
  • 1 x LTC I/O
Supported Cards
  • HDSPe MADI (PCI Express)
  • HDSPe AIO (PCI Express)
  • HDSPe PCI Card (PCI Express)
  • Other cards in multicard connection
BOB-32
Universal Breakout Box
The perfect addition to multichannel audio connections with 25-pin D-sub connectors. The ideal partner for a HDSP AES-32. With a BOB-32 all 16 XLRs can be connected in the 19" rack, instead on the slots behind the DAW. The BOB-32 comes with 2 different pinout formats, which can be switched between TASCAM, (Digidesign, RME) pinout or YAMAHA pinout format. One BOB fits all - making BOB-32 the ideal companion to RMEs HDSP AES-32, ADI-6432, Octamic-D, Micstasy, ADI-8 QS and all other devices that use digital D-sub connectors with TASCAM or YAMAHA pinout. BOB-32 offers a revolutionary flip-frame: The box can be "folded" in the middle, bringing all connectors to one side. BOB-32 is a passive I/O unit, no power supply needed.
Features
  • 8 x XLR Output
  • 8 x XLR Input
  • 2 x D-sub
Cables & Adapters for RME products
