How to handle a legend? Create a new!
The Multiface II is not only multi because of the many different interface formats supported, but also multi-Channel! The small box using half the space of a 19" rack includes outstanding power and extensive features.
Based on RMEs award-winning Hammerfall technology and equipped with the latest circuit designs of the Fireface 800, the Multiface II offers ADAT optical I/O, SPDIF I/O, MIDI I/O, word clock I/O and a separate hi-power monitor output.
On top there are 8 analog inputs and outputs, balanced and 24-bit/96kHz. All this can be used on laptops as well as on desktop computers with lowest latency and minimal CPU load.
Significant changes were provided to the internal core. The Multiface II integrates the more advanced featurs of Fireface- and OctaMic series:
Of course there are a lot typical RME features on board of the unit:
... and numerous other features found already in the Hammerfall series. And all this for an unbeatable price!
The front panel hosts some useful status LEDs, like MIDI state, lock state of the digital inputs and error state of the host-bus. Additionally there's a high-quality 24-Bit/96kHz analog line output, also usable with headphones, and one MIDI I/O.
The rear of the Multiface II shows unrivalled connectivity: 8 analog line I/Os on 1/4" TRS jacks (balanced, 24-Bit/96kHz), ADAT optical I/O (switchable to SPDIF optical), SPDIF I/O coaxial, word clock I/O and MIDI I/O. Don't settle for less!
The headphone output in hi-power technology offers high levels, even with low level headphones. Hence the headphone is direct usable with ASIO Direct Monitoring.
Digital I/Os: One ADAT optical I/O provides eight more channels. The coaxial SPDIF I/O is complete AES/EBU compatible.
The Multiface II can be used with laptops as well as desktop computers. The connection to laptops is achieved via a CardBus card or an ExpressCard, the connection to desktops via a PCI card or PCI Express card. These interfaces are sold separately.
Just click on the hammer symbol in the systray of the taskbar and the settings dialog of the Multiface comes up. The clear structured, easy to understand window plus the unique informative status windows for input signal, clock mode, sample rate and time code make your work with Hammerfall DSP System to a real pleasure. With a simple mouse click you gain access to the full power of your system.
When working with several digital sources it is not only necessary to know if these are properly locked, but also if they are totally synchronized. RME's exclusive SyncCheck checks all input signals and displays their actual state, and thanks to our new Intelligent Clock Control concept you have all clocks and states under control - with ease.
Regular firmware and driver updates ensure the Multiface II to stay at the top of today's audio interfaces. The latest addition, Disconnect mode, lets you use the unit as stand-alone AD/DA-converter, digital format converter, analog/digital mixer or submixer, and much more.
Supported sample rates: 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, variable
88 buffer sizes/latencies available: 1.5 ms, 3 ms, 6 ms, 12 ms, 23 ms, 46 ms, 93 ms, 186 ms
ASIO Zero CPU Load Technologie: 0 (zero!)% CPU load when using ALL 36 channels!
All settings changeable in real-time
Clock modes: slave and master
Automatic, intelligent master/slave clock control
Enhanced Mixed Mode: All inputs and outputs simultaneously operational
Unsurpassed Bitclock PLL (audio synchronization) in ADAT mode
Enhanced Zero Latency Monitoring for latency-free submixes and perfect ASIO Direct Monitoring
DIGICheck, the ultimate measurement, analysis and test tool
Dynamic ratio analog AD: 111.5 dB(A), DA: 112 dB(A)
THD+N AD: -98 dB (0.0012%), DA: -97 dB (0.0014%)
Analog level @ 0 dBFS (set by front panel switch): +2 dBV, +13 dBu, +19 dBu
Dynamic ratio stereo monitor output: 119 dB(A), 119 dBA, output impedance 30 Ohm
Input 8 x line (1/4" TRS jacks), 1 x optical (TOSLINK), 1 x coaxial (RCA), 1 x MIDI, word clock (BNC)
Digital input formats: SPDIF, AES/EBU (Consumer, Professional), ADAT optical
Outputs: 8 x line (1/4" TRS jacks), 1 x optical (TOSLINK), stereo analog line (TRS), 1 x coaxial (phono), 1 x MIDI, word clock (BNC)
Digital format Output: SPDIF, AES/EBU (Consumer/Professional), ADAT optical
Imprint | Terms of Use | Privacy Policy
Copyright 2010 Audio AG for RME Operations
Latency: This site was loaded in 0.002603 seconds.
