RME presents the world's most versatile PCI Express audio interface - the HDSPe AIO. This card makes the dream of an All-In-One solution for every possible application come true. The Advanced-Input-Output interface shines with the latest 192 kHz AD- and DA-converters, with more than 112 dB signal to noise ratio. For the first time, all inputs and outputs are simultaneously operational, even SPDIF (phono) and AES/EBU (XLR). Additional hi-quality analog inputs and outputs can easily be added by favourably priced expansion boards. Of course TotalMix, the unsurpassed flexible routing mixer and SteadyClock, RME's sensational clock technology with maximum jitter suppression of external clock signals, are on board too. HDSPe AIO also supports the optional TCO for synchronization to timecode (LTC/video). All this combines into a professional 'soundcard' that the world has not seen before.
HDSPe AIO is the newly developed PCI Express version of the HDSP 9632. A newly developed genuine PCI Express core consequently takes full advantage of the new format, achieving significant performance gains in multitrack audio and lowest latency. Thanks to RME's secure flash update technology, firmware improvements, adjustments, and bugfixes can be installed easily at any time.
The HDSPe AIO provides unique features:
* The HDSPe AIO ships in a basic version with analog RCA/phono breakout cables (headphone: TRS jack). Therefore all analog I/Os are unbalanced. An analog XLR breakout cable is available as option (headphone: Neutrik TRS locking jack), turning analog into balanced mode.
HDSPe AIO includes SteadyClock (TM), RME's own clock technology, combining professional features like maximum jitter suppression at full varipitch capabilities and software controlled sample rates.
Included software:
Just click on the hammer symbol in the systray of the taskbar and the settings dialog of the HDSPe AIO comes up. The clear structured, easy to understand window plus the unique informative status windows for input signal, clock mode and sample rate make your work with the card to a real pleasure.
When working with several digital sources it is not only necessary to know if these are properly locked,
but also if they are totally synchronized. RME's exclusive
SyncCheck
SyncCheck
When working with several digital sources it is not only necessary that these
are all properly locked, they also have to be totally synchronized.
Else drop outs and crackling occurs.
RME's exclusive SyncCheck checks all input signals.
In clock mode Master the synchronous operation to the internal clock is checked.
This outstanding and unique technology helps to find errors immediately.
The actual state of each input is displayed in the settings dialog.
© checks all input signals and displays their actual state, and thanks to RME's
Intelligent Clock Control (ICC)
Our unique SyncCheck and AutoSync technology has evolved into the new Intelligent Clock Control
of the Hammerfall DSP system. HDSP is the only digital I/O-system worldwide capable of measuring
and displaying the frequency of all clock sources. Even word clock! Based on validity and current
sample rate the system then decides which clock source should be used - fully automated and
performed in hardware! With this the HDSP system offers the most easiest handling of the present clocks,
although having a lot digital inputs, plus the most advanced support when configuring the clock setup.
concept you have all clocks and states under control - with ease.
Analog Expansions: An easy to handle ribbon cable connects the optional AI4S-192 AIO and AO4S-192 AIO. These analog expansion boards having one bracket with 4 stereo TRS jacks offer the same performance as the on-board stereo analog I/O of the HDSPe AIO: up to 192 kHz, balanced operation and 3 different reference levels. With this a maximum of 6 analog inputs and 8 analog outputs can be achieved.
Word Clock Expansion: The optional 9632 Word Clock Module provides a galvanically isolated word clock input and two word clock outputs via BNC jacks.
TDIF Expansion: HDSPe AIO can also provide a TDIF interface when using the TEB module.
| Expansion Boards | Optional analog and digital I/Os |
| HDSP TCO | Timecode Option Module with enhanced sync capabilities for HDSPe cards. 1 x word clock I/O, 1 x video sync input (switchable from wc in), 1 x LTC I/O |
1-Lane PCI Express Endpoint device (no PCI Express to PCI Bridge), revision 1.1.
2.5 Gbps line speed
Packet-based full-duplex communication (up to 500 MB/s transfer rate)
Supported sample frequencies: Internally 32, 44.1, 48, 64, 88.2, 96, 176.4, 192 kHz. Externally 28 kHz - 200 kHz
8 buffer sizes/latencies available: 0.7 ms, 1.5 ms, 3 ms, 6 ms, 12 ms, 23 ms, 46 ms, 93 ms
All settings changeable in real-time
Automatic and intelligent master/slave clock control
Enhanced Mixed mode: All inputs and outputs simultaneously operational
TMS (Track Marker Support): Supports CD/DAT start-IDs and the read out of CD subcode
Unique status windows for record and playback, showing mode and sample rate
DIGICheck, RMEs unique metering and analysing tool
Digital inputs and outputs ground-free transformer coupled
3-stage hardware level control for analog inputs and outputs
Balanced analog input and output, DC-coupled signal path
192 kHz / 24-bit converters. SNR 112 dB RMS unweighted, 115 dBA
Maximum input and output level (0 dBFS @ HiGain): +19 dBu
Low impedance headphone output (30 ohm), separate DAC and playback device
Super low jitter design: < 1 ns in all clock modes
Imprint | Terms of Use | Privacy Policy
Copyright 2010 Audio AG for RME Operations
Latency: This site was loaded in 0.002644 seconds.
