HDSP 9652 offers 3 x ADAT optical I/O, ADAT-Sync In, SPDIF I/O and word clock I/O. On top, there are 2 MIDI I/Os and TotalMix, a DSP-based real-time mixer/router, with hardware-calculated level metering and complete MIDI remote capability.
The HDSP 9652 also supports Expansion Boards (EXB). Two internal ADAT inputs and two internal ADAT outputs allow you to realize up to 16 analog inputs, 16 analog outputs, or up to two TDIF ports directly inside the computer.
Thanks to its unique Zero CPU Load technology Hammerfall DSP guarantees highest performance and lowest latency together with full flexibility!
The HDSP 9652's Secure BIOS Technology allows to perform hardware updates via software/driver without any risk.
The HDSP 9652 provides unique features:
... and numerous other features found already in the Hammerfall series. And all this for an unbeatable price!
Just click on the hammer symbol in the systray of the taskbar and the settings dialog of the HDSP 9652 comes up. The clear structured, easy to understand window plus the unique informative status windows for input signal, clock mode, sample rate and time code make your work with Hammerfall DSP to a real pleasure. With a simple mouse click you gain access to the full power of your card.
When working with several digital sources it is not only necessary to know if these are properly locked,
but also if they are totally synchronized. RMEs exclusive
SyncCheck
SyncCheck
When working with several digital sources it is not only necessary that these
are all properly locked, they also have to be totally synchronized.
Else drop outs and crackling occurs.
RME's exclusive SyncCheck checks all input signals.
In clock mode Master the synchronous operation to the internal clock is checked.
This outstanding and unique technology helps to find errors immediately.
The actual state of each input is displayed in the settings dialog.
® checks all input signals and displays their actual state, and thanks to our new
Intelligent Clock Control (ICC)
Our unique SyncCheck and AutoSync technology has evolved into the new Intelligent Clock Control
of the Hammerfall DSP system. HDSP is the only digital I/O-system worldwide capable of measuring
and displaying the frequency of all clock sources. Even word clock! Based on validity and current
sample rate the system then decides which clock source should be used - fully automated and
performed in hardware! With this the HDSP system offers the most easiest handling of the present clocks,
although having a lot digital inputs, plus the most advanced support when configuring the clock setup.
concept you have all clocks and states under control - with ease.
A display of the time code at the ADAT Sync-In port offers a quick check of the communication between external device and Hammerfall.
Supported sample rates: 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, variable
8 buffer sizes/latencies available: 1.5 ms, 3 ms, 6 ms, 12 ms, 23 ms, 46 ms, 93 ms, 186 ms
ASIO zero CPU load technology: 0 (zero!)% CPU load when using ALL 52 channels!
All settings changeable in real-time
Clock modes slave and master
Automatic and intelligent master/slave clock control
Enhanced Mixed mode: All inputs and outputs simultaneously operational
Unsurpassed Bitclock PLL (audio synchronization) in ADAT mode
Enhanced Zero Latency Monitoring for latency-free submixes and perfect ASIO Direct Monitoring
DIGICheck, the ultimate measurement, analysis and test tool
Input 3 x optical (TOSLINK), 1 x coaxial (RCA), 2 x MIDI, word clock (BNC)
Input format SPDIF, AES/EBU (Consumer, Professional), ADAT® optical
Output 3 x optical (TOSLINK), coaxial (RCA), 2 x MIDI, word clock (BNC)
Format output SPDIF, AES/EBU (Consumer/Professional), ADAT® optical
| Expansion Boards AEB 4-O/AEB 4-I | 4 analog inputs or outputs with 48 kHz. |
| Expansion Boards AEB 8-O/AEB 8-I | 8 analog inputs or outputs with 48 kHz. |
Imprint | Terms of Use | Privacy Policy
Copyright 2010 Audio AG for RME Operations
Latency: This site was loaded in 0.002193 seconds.
