      • HDSPe MADI FX
        • 390-Channel 192 kHz Triple MADI PCI Express card
      • 60-Channel, 24-Bit 192 kHz USB & FireWire Audio Interface
      • 36-Channel, 24-Bit 192 kHz USB & FireWire Audio Interface
      • 56-Channel, 24-Bit 192 kHz FireWire Audio Interface
    • HDSPe MADI FX
      • Bidirectional 64-Kanal 192 kHz MADI / AES3-id Format Converter
    • ADI-8 DS Mk III
      • 192 kHz 8-Channel High-End AES-EBU/ADAT AD/DA Converter
      • Optional Expansion Boards for HDSP PCI cards
      • External monitoring remote for Fireface UFX/UCX and others
      • Universal analog XLR/SUB-D Breakout Box
      • Universal XLR/SUB-D Breakout Box
    • Cables&Adapters
      • Cables and Adapters for RME products
      • Rackmounts for RME products
HDSP 9632
  • 32-Channel 24-Bit/192kHz
  • PCI Card
HDSP 9632
PCI & Cardbus Series
Internal Interfaces
External Interfaces
more information
Awards
MIPA Award
RME HDSP 9632
Overview
Connectivity
  • 1 x Analog I/O (192 kHz)
  • 1 x ADAT I/O (at 96 kHz via S/Mux)
  • 1 x SPDIF I/O (192 kHz)
  • 1 x MIDI I/O
  • 1 x Phones-Output
  • TotalMix
  • Expansion Boards (optional)
RME presents the world's most versatile PCI Audio Interface - the Hammerfall DSP 9632. This card makes the dream of an All-In-One solution for every possible application come true. As usual, RME has not made any compromises: Latest 192 kHz AD- and DA-converters with more than 110 dB signal to noise ratio, all inputs and outputs simultaneously operational, easy-to-install optional hi-quality analog expansion boards, the famous TotalMix, a newly developed sensational clock section with maximum jitter suppression of external clock signals - all this combines into a 'soundcard' that the world has been waiting for so long.
A PCI Express version (HDSPe AIO) is available.
Features
HDSP 9632
The HDSP 9632 provides unique features:
* The HDSP 9632 ships in a basic version including two RCA/phono breakout cables (headphone: TRS jack). Therefore all analog I/Os and the SPDIF I/O are unbalanced. XLR breakout cables are available as an option (headphone: Neutrik TRS locking jack), turning analog and AES/EBU into balanced mode.
HDSP 9632 debuts SteadyClock (TM), a newly developed clock technology, combining professional features like maximum jitter suppression at full varipitch capabilities and software controlled sample rates.
Compared to the well-known DIGI96/8 series, the HDSP 9632 not only offers a further improved analog interface, but also all the features of the award-winning Hammerfall DSP series: All inputs and outputs simultaneously available, MIDI I/O and TotalMix, the DSP-based real-time mixer/router. Hardware updates through software and driver updates are risk-free thanks to the Secure BIOS Technology.
In short: The HDSP 9632 is the ultimate audio interface for PC or Mac, digital or analog.
Settings
Just click on the hammer symbol in the systray of the taskbar and the settings dialog of the HDSP 9632 comes up. The clear structured, easy to understand window plus the unique informative status windows for input signal, clock mode and sample rate make your work with Hammerfall DSP to a real pleasure.
When working with several digital sources it is not only necessary to know if these are properly locked, but also if they are totally synchronized. RMEs exclusive SyncCheck SyncCheck
When working with several digital sources it is not only necessary that these are all properly locked, they also have to be totally synchronized. Else drop outs and crackling occurs.
RME's exclusive SyncCheck checks all input signals. In clock mode Master the synchronous operation to the internal clock is checked. This outstanding and unique technology helps to find errors immediately. The actual state of each input is displayed in the settings dialog.
® checks all input signals and displays their actual state, and thanks to our Intelligent Clock Control (ICC) Intelligent Clock Control (ICC)
Our unique SyncCheck and AutoSync technology has evolved into the new Intelligent Clock Control of the Hammerfall DSP system. HDSP is the only digital I/O-system worldwide capable of measuring and displaying the frequency of all clock sources. Even word clock! Based on validity and current sample rate the system then decides which clock source should be used - fully automated and performed in hardware! With this the HDSP system offers the most easiest handling of the present clocks, although having a lot digital inputs, plus the most advanced support when configuring the clock setup.
  concept you have all clocks and states under control - with ease.
Optional Add-Ons
Analog Expansions: An easy to handle ribbon cable connects the optional AI4S-192 AIO and AO4S-192 AIO. These analog expansion boards having one bracket with 4 stereo TRS jacks: up to 192 Khz, balanced and 3 different reference levels. With this a maximum of 6 inputs and/or outputs can be achieved.
Word Clock Expansion: The optional 9632 Word Clock Module provides a galvanically isolated word clock input and two word clock outputs via BNC jacks.
TDIF Expansion: HDSP 9632 supports also the TEB TDIF-I/O-Module.
Expansion Boards Optional analog and digital I/Os.
Tech Specs
Supported sample frequencies: Internally 32, 44.1, 48, 64, 88.2, 96, 176.4, 192 kHz. Externally 28 kHz - 200 kHz
8 buffer sizes/latencies available: 1.5 ms, 3 ms, 6 ms, 12 ms, 23 ms, 46 ms, 93 ms, 186 ms
All settings changeable in real-time
Automatic and intelligent master/slave clock control
Enhanced Mixed mode: All inputs and outputs simultaneously operational
TMS (Track Marker Support): Supports CD/DAT start-IDs and the read out of CD subcode
Unique status windows for record and playback, showing mode and sample rate
DIGICheck, RMEs unique metering and analysing tool
Digital inputs and outputs ground-free transformer coupled
3-stage hardware level control for analog inputs and outputs
Balanced analog input and output, DC-coupled signal path
192 kHz / 24-Bit converters. SNR 110 dB RMS unweighted, 113 dBA
Maximum input and output level (0 dBFS @ HiGain): +19 dBu
Low impedance headphone output (75 ohm), stepless output level through software faders
Headphone Speaker Protection minimizes noise during power on/off
Super low jitter design: < 1 ns in all clock modes
Accessories
