      • 60-Channel, 24-Bit 192 kHz USB & FireWire Audio Interface
      • 36-Channel, 24-Bit 192 kHz USB & FireWire Audio Interface
      • 56-Channel, 24-Bit 192 kHz FireWire Audio Interface
      • Bidirectional 64-Kanal 192 kHz MADI / AES3-id Format Converter
      • Optional Expansion Boards for HDSP PCI cards
      • External monitoring remote for Fireface UFX/UCX and others
      • Universal analog XLR/SUB-D Breakout Box
      • Universal XLR/SUB-D Breakout Box
    • Cables&Adapters
      • Cables and Adapters for RME products
      • Rackmounts for RME products
ADI-8 PRO
  • High-Precision 8-Channel 48 kHz
  • ADAT.TDIF AD/DA converter
ADI-8 PRO
Audio/Format Converters
more information
RME ADI-8 PRO
Overview
Der ADI-8 PRO ist ein 8-kanaliger Analog zu Digital- and Digital zu Analog-converter mit Referenz-Qualität. Das kompakte Gerät mit 19" Breite and 1 HE verfügt über zahlreiche außergewöhnliche Features, wie Intelligent Clock Control (ICC), SyncCheck SyncCheck
When working with several digital sources it is not only necessary that these are all properly locked, they also have to be totally synchronized. Else drop outs and crackling occurs.
RME's exclusive SyncCheck checks all input signals. In clock mode Master the synchronous operation to the internal clock is checked. This outstanding and unique technology helps to find errors immediately. The actual state of each input is displayed in the settings dialog.
®, SyncAlign SyncAlign
SyncAlign includes several methods and techniques to guarantee absolute data alignment with regard to time and channels. No RME digital audio card will ever swap channels, not in stereo nor in multi channel mode, regardless what you do with the card and the signals it gets. SyncAlign also controls the timing among the channels, no matter how much are used, they will always start sample-aligned.
When the record while play mode is activated, the corresponding software first starts record and then playback (or playback then record.) SyncAlign can compensate the time difference so that an exact simultaneous start of record and playback in the record while play mode is guaranteed. In asynchronous mode (different programs use different stereo devices of one card) this part of SyncAlign is automatically deactivated.
®, TDIF/ADAT Converter, digitale Patchbay and Bit Splitter. AD- and DA-Teil arbeiten sowohl vollkommen unabhängig als auch intelligent gekoppelt. Morne 24-Bit converter mit 128 fachem Oversampling ergeben über 110 dB reale dynamic, die volle Auflösung von 24-Bit steht auch an allen digitalen Inputs and Outputsn zur Verfügung. Wenn Sie auf einen flexiblen, voll professionellen aber erschwinglichen Mehrkanal-converter gewartet haben - hier ist er!
Vergleichen Sie die folgenden Hi-End Features des ADI-8 PRO mit allen anderen Mehrkanal-convertern, and Sie werden uns zustimmen: Der ADI-8 PRO weist ein unübertroffenes Preis/Leistungsverhältnis auf!
Features
Die erstaunlichen Fähigkeiten des ADI-8 PRO erschliessen sich dank einer konsequent logischen Bedienoberfläche wie von selbst. Begleiten Sie uns bei einer kleinen 'Tour de ADI' von links nach rechts über die Frontplatte. Die Konfiguration beginnt mit der richtigen Inputsempfindlichkeit. Um die extreme dynamic der hochwertigen AD-converter nicht durch eine ungünstige Pegelanpassung zu vermindern, kann die Inputsempfindlichkeit über den Taster INPUT LEVEL zwischen -10 dBV, +4 dBu and Lo Gain verändert werden.
Jeder analoge Input besitzt seine eigene 'Signal Present' and 'Clip' LED, so dass jeder Kanal in Bezug auf Inputssignal and Übersteuerung kontrollierbar ist. Der Taster BIT SPLIT aktiviert die Verteilung des 24-Bit Digitalsignals auf zwei Ausgänge. Damit ist es beispielsweise möglich mittels zweier 8-Kanal 16-Bit Bandmaschinen in 24-Bit Auflösung aufzunehmen (8 x 24-Bit wird auf 16 x 16-Bit verteilt). Das Bit Split Verfahren ist sowohl mit TDIF als auch ADAT möglich.
RMEs intelligente Clock Steuerung ICC bietet umfassende and professionelle Möglichkeiten die Ihresgleichen suchen. Zunächst ist die Clock-Quelle des AD-converters zwischen Intern (Quarz), Extern (BNC Word Clock) and Input (das digitale Inputssignal TDIF/ADAT) wählbar. Bei Intern ist 44,1 kHz or 48 kHz möglich. Für den DA-converter bestehen exakt die gleichen Optionen. Lock Zustand and Clock Synchronität werden über den Status der jeweiligen LED (Blinkend/Konstant) angezeigt. Der nächste Taster DIGITAL INPUT entscheidet sowohl über den verwendeten digitalen Input des DA-converters (ADAT or TDIF) als auch über die Clock-Quelle, falls zuvor INPUT gewählt wurde.
Der Taster DIGITAL INPUT gehört bereits mit zur DA-Sektion. Es folgt die Umkehrung des Bit Split - COMBINE - welches zuvor gesplittete Signale wieder zu 24-Bit zusammenfügt. Der Taster COPY MODE routet das digitale Inputssignal zusätzlich zu den digitalen Ausgängen (ADAT and TDIF.) Da die Ausgänge immer parallel laufen verwandelt sich der ADI-8 PRO nicht nur in einen exzellenten ADAT/TDIF Converter, sondern erlaubt auch das Kopieren zwischen Geräten gleichen Formates sowie das Verteilen auf unterschiedliche and gleiche Geräte. Beispielsweise verteilt der ADI-8 PRO ein ADAT Signal auf 2 ADAT and 2 TDIF Ausgänge gleichzeitig. BIT SPLIT and COMBINE stehen im Copy Modus ebenfalls bereit, so dass neben dem Kopieren/Konvertieren zwischen ADAT and TDIF auch das Re-Kombinieren vormals gesplitteter Signale, das Splitten nicht gesplitteter Signale and das Splitten Re-Kombinierter Signale möglich ist. Damit stellt der ADI-8 PRO ein extrem leistungsfähiges Interface zwischen TDIF and ADAT dar.
Jeder analoge Outputskanal hat seine eigene 'Signal Present' LED, welche in analoger Form anzeigt (heller mit höherem Pegel). Ein Druck auf OUTPUT LEVEL entscheidet zwischen -10 dBV, +4 dBu or Hi Gain Outputspegel.
Die Rückseite des ADI-8 PRO zeigt die beeindruckende Anzahl an Buchsen and Steckverbindern, welche eine unschlagbare Flexibilität and Kompatibilität ergeben. Was auch immer es ist - einfach anschließen and loslegen! Genießen Sie eine Klangtreue and Klarheit des Klanges, wie Sie sie bei Multitrack-Aufnahmen bisher immer vermisst haben!
ADI-8 Inside (Auszug)
Der ADI-8 PRO gliedert sich intern in verschiedene Funktionsblöcke:
Den internen Aufbau eines ADI-8 PRO zeigt dieses Foto anhand eines geöffneten Gehäuses.
Wie im Schematic view übersichtlich dargestellt besitzt der ADI-8 PRO eine Fülle interner Routingmöglichkeiten, welche zusätzlich zum Betrieb als AD- and DA-converter eine Nutzung als Formatkonverter, Distributor and Splitter erlauben.
Analog zu Digital
Die analogen Eingänge sind über Stereo-Klinkenbuchsen or einen 25-poligen D-Sub Anschluss zugänglich. Letzterer besitzt die gleiche Pinbelegung wie die weit verbreiteten Digitalrecorder der Firma Tascam, so dass ein passendes Multicorekabel (für direkten Anschluss an Mischpulte or als XLR-Adapter) problemlos beschaffbar ist. Die gesamte Inputsstufe ist von den Buchsen bis zu den internen Anschlüssen der converter-ICs vollständig symmetrisch aufgebaut. Die ungewöhnliche Schaltung arbeitet zudem servosymmetrisch. Das bedeutet: Bei unsymmetrischem Anschluss erfolgt eine automatische Pegelkorrektur um 6 dB, welcher sonst zu einem Absinken der Inputsempfindlichkeit gegenüber symmetrischem Anschluss führen würde.
Jeder A/D-converter ist nur so gut wie die Pegelanpassung an seinem Input, weshalb der ADI-8 PRO drei verschiedene Inputspegel unterstützt. Dadurch ist ein problemloser Anschluss an alle typischerweise in einem Studio vorkommenden Geräte gewährleistet, Verluste schon vor der AD-Wandlung werden vermieden. Die Umschaltung zwischen Lo Gain, +4 dBu and -10 dBV erfolgt über einen besonderen Schaltungstrick direkt in der symmetrischen Inputsstufe, wobei es mornste elektronische Schalter neuester Fertigungstechnik (ADG 451) erlauben, den Schalter an der Stelle im Layout bzw. Signalweg einzusetzen, wo er optimal platziert ist. Zusätzliche Verstärkungsschaltungen or lange Kabelwege zu mechanischen Elementen entfallen komplett. Die AD-converter erhalten das Inputssignal in bestmöglicher Qualität, and erreichen ihren maximalen Rauschabstand bei einem Minimum an Verzerrungen.
Lesen Sie den gesamten Artikel in unserer Rubrik "Tech Info"
Tech Specs
Input AD: 6,3 mm Stereoklinke and 25 pol. D-Sub, servosymmetrisch, komplett symmetrischer, DC-gekoppelter Signalpfad
Output AD: ADAT optical, TDIF-1 (je 24-Bit), Word Clock
Input DA: ADAT optical, TDIF-1 (je 24-Bit), Word Clock
Output DA: 6,3 mm Stereoklinke and 25 pol. D-Sub, servosymmetrisch, DC-gekoppelter Signalpfad
dynamic AD: 116 dB(A)
THD AD: < -110 dB (< 0.00032 %)
THD+N AD: < -102 dB (< 0.0008 %)
Überprechdämpfung AD: > 130 dB
dynamic DA: 112 dB(A) unmuted
THD DA: < -104 dB (< 0.00063 %)
THD+N DA: < -102 dB (< 0.0008 %)
Übersprechdämpfung DA: > 110 dB
Ein-/Outputspegel bei 0 dBFS @ Hi Gain: +19 dBu
Ein-/Outputspegel bei 0 dBFS @ +4 dBu: +13 dBu
Ein-/Outputspegel bei 0 dBFS @ -10 dBV: +2 dBV
Frequenzgang AD/DA, -0,1 dB: 5 Hz - 21,5 kHz
Stromversorgung: Internes Schaltnetzteil, 100 V-240 V AC
Warranty: 2 years
