ADI-8 DS is an 8-Channel AD/DA converter with reference approach. The compact 19" 1U rackmount enclosure
includes several outstanding features, like
Intelligent Clock Control (ICC)
Our unique SyncCheck and AutoSync technology has evolved into the new Intelligent Clock Control
of the Hammerfall DSP system. HDSP is the only digital I/O-system worldwide capable of measuring
and displaying the frequency of all clock sources. Even word clock! Based on validity and current
sample rate the system then decides which clock source should be used - fully automated and
performed in hardware! With this the HDSP system offers the most easiest handling of the present clocks,
although having a lot digital inputs, plus the most advanced support when configuring the clock setup.
SyncCheck
SyncCheck
When working with several digital sources it is not only necessary that these
are all properly locked, they also have to be totally synchronized.
Else drop outs and crackling occurs.
RME's exclusive SyncCheck checks all input signals.
In clock mode Master the synchronous operation to the internal clock is checked.
This outstanding and unique technology helps to find errors immediately.
The actual state of each input is displayed in the settings dialog.
SyncAlign
SyncAlign
SyncAlign includes several methods and techniques to guarantee absolute data alignment
with regard to time and channels. No RME digital audio card will ever swap channels,
not in stereo nor in multi channel mode, regardless what you do with the card and the
signals it gets. SyncAlign also controls the timing among the channels, no matter how
much are used, they will always start sample-aligned.
When the record while play mode is activated, the corresponding software first starts record
and then playback (or playback then record.) SyncAlign can compensate the time difference
so that an exact simultaneous start of record and playback in the record while
play mode is guaranteed. In asynchronous mode (different programs use different
stereo devices of one card) this part of SyncAlign is automatically deactivated.
®, TDIF/ADAT converter and Bit Splitter. AD- and DA-circuit automatically operate either independently or linked. The latest 24-Bit
converters with 128 times oversampling achieve 117 dBA true dynamic range. All digital inputs and outputs operate
at full 24-bit resolution. If you have been waiting for a flexible, fully professional yet affordable multi-Channel
converter - the wait is over!
The ADI-8 DS is nearly identical to the ADI-8 PRO. Additional features include 88.2 and 96 kHz sample rate and Dither. DS stands for Double Speed, meaning double sample rate. As ADAT optical does not support sample rates higher than 48 kHz the DS mode requires two channels to transmit the data of one channel. The used method called Sample Split is compatible to S/MUX, and also found in the Hammerfall and Hammerfall Light. The combination Hammerfall/ADI-8 DS allows DVD-compatible Hi-End recordings (up to 8 channel @ 96 kHz), at an astonishing low price.
Use the following feature list to compare our ADI-8 DS with all other multitrack converters, and you will agree: The ADI-8 DS has the best price/performance ratio!
There is a Broadcast version of the ADI-8 DS available: ADI-8 DSB. The DSB version provides a different I/O level of +6 dBu instead the +4 dBu of the standard version.
The ADI-8 DS' astonishing capabilities are easy to explore thanks to a simple and easy to understand user interface. Let's have a short walk over the front panel from left to right. Setting up the ADI-8 DS starts with an input sensitivity that perfectly suits your needs and maintains the excellent dynamic range of the AD-Converters. INPUT LEVEL lets you choose between Lo Gain, +4 dBu, -10 dBV.
Each analog input has its own 'Signal Present' and 'Clip' LED, so levels and Overload are easy to check. The key PROCESS activates Bit Split (spread the 24-Bit signal on two outputs), Double Speed mode (DS) and Dither (Dith.) Bit Split allows two 8-Channel 16-Bit tape recorders to record 8 channels in 24-Bit resolution. Bit Split works with both TDIF and ADAT.
RMEs intelligent clock control (ICC) provides professional features you won't find anywhere else. First set the clock of the AD-Converter, choose between INTERNAL, EXTERNAL (BNC word clock) or INPUT (the digital input signal ADAT or TDIF.) The internal clock can be 44.1/48 or - when DS is active - 88.2 or 96 kHz. The DA-Converter has the same settings available. The current state of locking and clock synchronization is shown by blinking or constantly lit LEDs. The next key DIGITAL INPUT determines the used digital input, and the clock source in case INPUT was activated.
DIGITAL INPUT is already part of the DA-Converter section. Next is COMBINE which activates both the re-combination of split signals back to a full 24-Bit signal and Double Speed mode. The key COPY MODE routes the digital input to the digital outputs ADAT and TDIF. As these operate simultaneously sending identical data the ADI-8 DS not only turns into a superior ADAT/TDIF converter, but also allows copying between devices of the same format and a distribution to different devices. For example an ADAT signal can be distributed to 2 ADAT plus 2 TDIF outputs simultaneously. In Copy Mode also both Bit Split and COMBINE are available, so it's possible to recombine a split signal while copying, or split a not split signal, or recombine and split again into another format. With this the ADI-8 DS turns into an extremely powerful TDIF/ADAT interface.
Each analog output has its own 'Signal Present' LED which works in an analog fashion (brighter at higher levels.) A push on OUTPUT LEVEL sets Hi Gain, +4 dBu or -10 dBV as analog output level.
ADI-8 DS's back shows an impressive number of connectors of all kinds which result in an unbeaten flexibility and compatibility. Whatever it is - simply get connected and enjoy the sonic clarity you've been missing when doing multitrack recording for so long.
The ADI-8 DS internal structure can be divided into 4 distinct functional blocks:
This photo shows the internal structure of an ADI-8, after having opened the case.
As the Schematic view clearly shows, the ADI-8 can be routed internally in many ways which, in addition to its function as A/D-D/A converter, allows it to be used as a format converter, distributor or splitter.
Physical access to the analogue inputs is either via 1/4" stereo jack socket or 25-pin D-type connector conforming to the Tascam DAxx analogue I/O pinout. These recorders are very common, so a suitable multicore cable (e.g. for connecting directly to mixing consoles or to XLR) should be relatively easy to find. The entire input stage - from the sockets to the converter chip's internal input - is fully symmetrical. This is a special servo-balanced input circuit: if the signal at the input is unbalanced, input gain is automatically adjusted by +6 dB. Otherwise input sensitivity for an unbalanced signal would have been lower than for a balanced one.
Any A/D converter is only as good as the gain compensation at the input. The ADI-8 has 3 gain levels, making it compatible with a wide range of studio equipment - loss is avoided before the signal gets to the A/D converter. Input gain is switchable between Lo Gain, +4 dBu and -10 dBV, and employs a special damping technique: using latest hi-grade electronic switches (ADG 451), the gain switch could be placed in the best possible position within the signal path. This approach makes additional amplifier circuitry or long cables to mechanical components unnecessary (and obsolete.) The D/A converters get the best quality signal possible, so they can reach maximum SNR (signal-to-noise ratio) with minimum distortion.
Please study the complete article "ADI-8 Inside" in our "Tech Info"
Input AD: 1/4" TRS jack and 25 pin D-type connector, servo balanced, completely symmetrical DC-coupled audio path
Output AD: ADAT optical, TDIF-1 (both 24-bit), word clock
Input DA: ADAT optical, TDIF-1 (both 24-bit), word clock
Output DA: 1/4" TRS jack and 25 pin D-type connector, servo balanced, DC-coupled audio path
SNR AD: 117 dB(A)
THD AD: < -110 dB (< 0.00032 %)
THD+N AD: < -104 dB (< 0.00063 %)
Crosstalk AD: > 130 dB
SNR DA: 112 dB(A) unmuted
THD DA: < -104 dB (< 0.00063 %)
THD+N DA: < -102 dB (< 0.0008 %)
Crosstalk DA: > 110 dB
Input/Output level at 0 dBFS @ Hi Gain: +19 dBu
Input/Output level at 0 dBFS @ +4 dBu: +13 dBu
Input/Output level at 0 dBFS @ -10 dBV: +2 dBV
Frequency response AD/DA -0,1 dB: 5 Hz - 21,5 kHz (sf 48 kHz)
Frequency response AD/DA -0,5 dB: < 5 Hz - 44,8 kHz (sf 96 kHz)
Power supply: internal, 100 V-240 V AC, 100 V-240 V AC
Dimensions 483 x 44 x 200 mm
Warranty: 2 years
Imprint | Terms of Use | Privacy Policy
Copyright 2012 Audio AG for RME Operations
Latency: This site was loaded in 0.011472 seconds.
